Michiel
Cat Cams
1. Cat Cams Sport nokkenassen (2290610 - onbekend RPM - OEM klepveren)
inlaat: 254 graden / 9.30mm lift - ATDC @ full lift = 110 / timings: BTDC = 2; ABDC = 42
uitlaat: 250 graden / 8.90mm lift - BTDC @ full lift = 106 / timings: BBDC = 33; ATDC = 1
2. Cat Cams Rally & Cross nokkenassen (2290605 - onbekend RPM - OEM klepveren)
inlaat: 262 graden / 9.30mm lift - ATDC @ full lift = 110 / timings: BTDC = 5; ABDC = 45
uitlaat: 254 graden / 9.30mm lift - BTDC @ full lift = 106 / timings: BBDC = 38; ATDC = 6
3. Cat Cams Rally & Race nokkenassen (2290609 - onbekend RPM - OEM klepveren)
inlaat: 270 graden / 9.75mm lift - ATDC @ full lift = 110 / timings: BTDC = 11; ABDC = 51
uitlaat: 262 graden / 9.30mm lift - BTDC @ full lift = 106 / timings: BBDC = 41; ATDC = 9
4. Cat Cams Rally & Race nokkenassen (2290608 - onbekend RPM - OEM klepveren)
inlaat: 279 graden / 10.25mm lift - ATDC @ full lift = 110 / timings: BTDC= 15; ABDC = 55
uitlaat: 270 graden / 9.75mm lift - BTDC @ full lift = 106 / timings: BBDC = 47; ATDC = 15
5. Cat Cams Rally & Cross nokkenassen (2290613 - onbekend RPM - upgrade klepveren en veerschotels)
inlaat: 261 graden / 11.30mm lift - ATDC @ full lift = 106 / timings: BTDC = 11; ABDC = 42
uitlaat: 256 graden / 10.30mm lift - BTDC @ full lift = 106 / timings: BBDC = 37; ATDC = 4
6. Cat Cams Rally & Cross nokkenassen (2290611 - onbekend RPM - upgrade klepveren en veerschotels)
inlaat: 267 graden / 12.00mm lift - ATDC @ full lift = 106 / timings: BTDC = 13; ABDC = 45
uitlaat: 261 graden / 11.30mm lift - BTDC @ full lift = 106 / timings: BBDC = 42; ATDC = 11
7. Cat Cams Rally & Race nokkenassen (2290612 - onbekend RPM - upgrade klepveren en veerschotels)
inlaat: 272 graden / 12.50mm lift - ATDC @ full lift = 106 / timings: BTDC = 15; ABDC = 47
uitlaat: 267 graden / 12.00mm lift - BTDC @ full lift = 106 / timings: BBDC = 45; ATDC = 13
8. Cat Cams Rally & Race nokkenassen (2290617 - onbekend RPM - upgrade klepveren en veerschotels)
inlaat: 293 graden / 11.95mm lift - ATDC @ full lift = 106 / timings: BTDC = 22; ABDC = 54
uitlaat: 283 graden / 11.50mm lift - BTDC @ full lift = 106 / timings: BBDC = 49; ATDC = 18
Website
Te koop bij:
Catcams NV
Autolei 145-151
2160 Wommelgem
België
T: +32-33202560
F: +32-33223677
E: info@catcams.be
Greenspeed NV
Linkebeeksedreef 73
1640 Sint-Genesius-Rode
België
T: +32-23582919
F: +32-23585161
E: greenspeed@euronet.be
MRD S.P.R.L
Chaussee de Huy 49A
4280 Hannut
België
T: +32-19510544
F: +32-19514086
E: mrd@skynet.be
Stefco Motorsport
Deurnestraat 243
2640 Mortsel
België
T: +32-34404212
F: +32-34480450
E: info@stefco.be
Beek Autoracing
Weser 6
2267 CN Leidschemdam
Nederland
T: +31-70-3206579
F: +31-70-3207802
E: info@beekautoracing.nl
Emming Motorentechniek
Poortweg 3
9561 LJ Ter Appel
Nederland
T: +31-599585006
Van Kronenburg
Spaarpot Oost 19
5667 KT Geldrop
Nederland
T: +31-40-2854064
F: +31-40-2867765
E: info@van-kronenburg.nl
Welke kan je het beste kopen wanneer je alleen een ander luchtfilter en andere uitlaat zonder restrictie in de flexpijp, racecat en 600mm gasklep hebt? (Chippen komt later)
Hier heb ik nog vrij weinig ervaring mee en kan wel wat advies hierin gebruiken.
Ok, en dat helpt dan weer de motor aan gort dus?
Ik zal eens rond kijken!
kom bij mebu langs zo ik zeggen daar staan straks verbouwde st met cosworth cams erin. En praat met jaap erover als je het veilig wilt doen zonder ellende erna.
Als ik er aan toe ben kan ik dat wel doen, het is voor mij wel compleet aan de andere kant van NL.
Create an account
Register a new account
Sign in
Sign In Now
